  • Changing font on L9 plus Nigeria
    please how do I change font on my Tecno l9 plus
    Hi Sammy2nyce This Feature is not enabled on the L9 Plus. You can only adjust the size. This is a fact.
    Hot-line: 08138615848, 09098834535
    Address: NO. 77, OPEBI ROAD, IKEJA.
    Facebook: http://bit.ly/2m4htYp
    Twitter: http://bit.ly/2m4hM5v
    Carlcare Service Centre | Yes, we care!
    • Sammy2nyce commented
      @ogbemi, thanks bro.. <br />
      please this issue of changing font on Tecno l9 plus should be looked into
    damn!
      damn!
      Hi Sammy2nyce The issue has been rectified. Visit the Carlcare Service Centre closest to you for a Software Update. You may Book a reservation using the Carlcare Application on your device [and give the information required]; Our contact number(s) and addresses are also in the App Or let me know your location so that I forward one to you. Thank you!
        my address is No 3/5 Nwosu street off 26 umule, Aba, abia state.
      I think there's an update for the L9 Plus. Visit Carl care as said by @ogbemi
        do you use L9 plus too?
          No 3/5 Nwosu street off 26 umule, aba, Abia state
