  • WX3P inner memory problem Others
    please how do i fix the inner memory of my phone as it claims i have used over 7GB when i haven't used even half of it... i have also browsed through the phone and saw nothing occupying the memory... i use a Tecno WX3P
    Dear Richardoba,<br />
    I hope you are aware there are pre-installed apps on your device and this apps too share phone storage. If you are not still satisfied, kindly restore factory settings and see the actual memory being taken up by pre-installed apps. <br />
      what is the memory space of your phone? some apps store data irrelevant ones most times
        dear fam, the system itself do take some reasonable amount on your phone storage.
        ​So some space is used by the system
