  • TECNO Spark K7 Kenya
    Basically it the most classic phone in the market now. Its quite well balanced in terms of performance and perfection -given the stylish body. Indeed they do understand their customers needs and make no mistake in delivering on that.
    thanks for the positive feedback
    i am glad you are enjoying your device.
    Thanks for using Tecno mobile
    • kenyambi commented
      But it's not displaying the fonts
    I am glad you are enjoying your device, Tecno always looking for better ways to satisfy its customers.<br />
    Kepp On Using Tecno-Mobile.
      thank you for the feedback.. enjoy your device.
      ‚ÄčAnd welcome to the family, glad to have you here
        but the battery doesn't last very well
        • Mr_Goumestin commented
          root it i you will see
        k7 how much
          are there more phone cases for tecno k7?
            the one am using has a problem in network connection, I can't browse,plz help
              The phone is very nice.. the camera is sparkling and the finger print is wow!!! but the problem I am facing is that the some Edited picture fail to display. it would write "Can't display thumbnail " what could be the cause please?
                I love my phone TECNO CX so amazing
                  . I got the same problem. as for me the intenet connection is low
                    Is it possible to hide gesture?
                      Hello guys, in my Tecno Spark whenever u change my ring tone then maybe I switch off the phone over night, then I do discover that that the ring tone has been reset to a default ring tone. Why?
                        I can't use a luncher of my choice why ??
                        • waku7bisha commented
                          you can. just go to settings > apps > click that gear icon on the top right > click home app > then choose your launcher.
                        you can use the launcher of choice... just go to settings..then apps..then click the setting icon on top right corner...then click home app..choose the home app of your choice@fahis
