  • an update for Tecno w3 phone All
    is there an update of Tecno w3?
    you can check it from your device...do it?
      go to settings, software and check for that
        you can check on the "system update" app on your device
          I haven't used this phone. But, I have read the uk superior papers reviews about this phone which got good reviews from the users. i really want to buy this phone.
            there's an update but if you're not lucky you'll encounter problems after upgrading it.<br />
            I'm facing some problem.<br />
            the Sim one is not working, you have to put it to loud speaker before you can make calls.beware
              the Data too is not working anymore
