  • 7 Frequent Android Nougat Problems and Quick Solutions Nigeria
    Hi T-Fans,
    Last year, in the month of August, Android 7.0 Nougat was released and now it has already got updated to Android 7.1. Since, the release of Nougat, both 7.0 and 7.1 are running on most number of Tecno devices like Camon CX series, Spark series, Phantom 6 plus (OS upgrade) and Phantom 8.
    But users are facing several problems after updating their Android to Nougat. We don’t say Android 7.0 or 7.1 upgrade is absolutely not useful, you can find Android 7.0, 7.1 has got some amazing features, but yes it is true that every new thing have some bugs and that needs to be fixed.
    Similarly, there have been several users out there encountering different types of problems on their Android running on Nougat 7.0, 7.1.
    So, from the several Nougat problems we have listed the most common Android Nougat problems and their solutions. Just go through them, I hope you might get the solutions for your Nougat problems or issues.
    Most Common Android Nougat Problems and Their Fixes:
    Problem #1: Fast & Quick Battery Drain
    Problem #2: Wi-Fi And Bluetooth Connectivity Problem
    Problem #3: Charging Problem
    Problem #4: Lagging, Hanging and Performance Issue
    Problem #5: Unstable or Crashing App
    Problem #6: Mobile Data Connectivity Issue
    Problem #7: Data Loss Problem
    Fast & quick battery drain is the most major problems that are faced by so many Android 7.0 Nougat users.
    Solutions: How to fix fast battery drain issue on Android Nougat
    Below find out the solution on how to solve fast battery drain issue on Android Nougat.
    •The first thing you should do – simply reduce the display brightness and screen lock time.
    Turn OFF mobile data, Wi-Fi or Bluetooth when not needed and also close unwanted apps running in the background and uninstall unwanted apps that you do not use.
    •Second thing you should do – check battery saver is enabled on your device or not. If not, then enable it from battery settings menu.
    •And finally check for battery optimization option. Go to Setting > Battery and tap on 3 vertical dots.
    This will display the battery optimization option. Now check if any app has opted out of battery saver feature. Tap on 3 dots and select Reset app preference. Hope this might fix the problem for you.
    Some of the Phantom 6 Plus and W series phone users are facing Wi-Fi and Bluetooth connectivity issue in Android 7.0, 7.1 Nougat.
    Solutions: How to Fix Wi-Fi And Bluetooth Connectivity Problem on Nougat
    Below you can find out the basic solution on how to fix Wi-Fi and Bluetooth connectivity issue on Nougat:
    Note: Before following below solutions, make sure the problem is with Nougat only. Check with other devices and see if Wi-Fi and Bluetooth are still creating the same issue. If not, then it is confirmed that the problem is within your device or OS.
    •The first thing you should do – Switch OFF your phone and wait for few seconds or 1 minute and then Switch it ON and check if the problem is solved.
    •The second thing you should do – disable the Wi-Fi and Bluetooth and then again enable them and see if it has fixed the issue.
    •The third thing you should do – When connecting to Wi-Fi, try to forget the network and then reconnect them. Go to Settings> More > Network settings reset > Reset settings. May be this can fix the issue.
    •And, finally perform factory reset, if none of the solutions work for you. Remember factory reset will erase all data from your device hence, you must backup & restore everything before performing factory reset. To do factory reset go to Settings > Backup & reset > Factory data reset and select to erase all data.
    Charging problem has also been one of the common issue and many users are experiencing it on device running on Android Nougat 7.1.1. According to one Phantom 6 Plus user – charging has stopped after receiving Android 7.1 Nougat via OTA.
    Solutions: How to Fix Charging Issue on Nougat
    Below you can find few solutions that could help you to solve charging issue on Android Nougat:
    •The first thing you should do – make sure you are using the original (oraimo) charger that has came with the device for charging your smartphone. Do not use non-original charger or third party charger please.
    •The second thing you should do – if you are charging your device with wall charger, then switch it to USB and charge your phone from computer or laptop.
    Lagging , hanging and performance issue has also been noticed by many users after updating their device to Nougat. Here find out user facing – Phone hangs/Lagging after Updating to Nougat.
    Solutions: How to Fix Lagging, hanging and Performance Issue on Nougat
    Below you can find out some solutions that can help you to solve lagging and performance issue on Nougat:
    •The first thing you should do – Check RAM Manager Tool that comes with Android Nougat 7.0. This tool will allow you to check what is making your device to run slow. You can access this tool under Settings > Memory.
    •The second thing you should do – if your device is full with unwanted data like photos, videos, etc, then delete or move those files to another external device. Deleting the data will free up some space and thereby your device will not hang or freeze.
    •The third thing you should do – install Qualcomm’s Trepn Profiler app from play store. This app keeps an eye to device’s CPU activity.
    •And, finally, you can perform a factory reset.
    Apps crash after Android N upgrade is another issue that is reported by several users after they updated their device to Nougat.
    Solutions: How to Fix Unstable or Crashing App on Nougat
    Though it is small issue but for normal users it can be big problem and they may get frustrated and annoyed. Below find out few solution that can help you to fix App crashing on Nougat:
    •The first thing you should do – simply uninstall and re-install the app which is creating the problem. But before uninstalling the app you must backup the data for that specific app.
    •The second thing you should do – clear cache and data of the app creating the issue. May be this can help you to fix the problem. Go to Settings> Apps> Look for the app creating the issue> tap on it. You can see the clear cache and clear data option.
    •And, finally, if above mentioned solution fails then perform factory reset on your device.
    There are many users out there have reported that they are not able to get mobile data service on their device.
    Solutions: How to Fix Mobile Data Connectivity Issues on Nougat
    When user get mobile connectivity issue on their phone, they usually contact their carrier, but before you contact your carrier below find out some solution that may help you to fix mobile data connectivity issues on Nougat:
    •The first thing you should do – Switch OFF your phone, wait for few seconds and then switch it ON. You can also Reboot your device. May this fix can help you connect mobile data on your device.
    •The second thing you should do – Enable Airplane mode, it will disconnect all the connection. Now disable Airplane mode and check if problem is solved.
    •The third thing you should do – disable cellular data or LTE option on your device from Setting option and then TURN them ON and check if this fix your issue.
    •And, finally if all solution fails, then perform a factory reset on your phone.
    There have been many users out there facing data loss problem after Android 7.0 or 7.1 update.
    Solutions: How to Recover Data After 7.0 Nougat Update
    Check your Google drive. If you have synced your photos, videos contacts, then you can check your Gmail account or Google Drive for photos, videos or contacts.
    Or you can also use recommended Nougat Data Recovery software, to restore entire data such as photos, videos, contacts, SMS, whatsApp data, notes, voice recordings, audio, documents files and more.
    In Conclusion
    So, those were common but most occurring Android 7.0, 7.1 Nougat problems and there solutions. If you are encountering any of the above mentioned issues, then you can follow the respective solution or steps to fix the issue.
    Please always make sure you update your phone firmware/software whenever an update is available.
    However, if your phone is under warranty, then you can go for replacement or take it to the nearest Carlcare service center.
    IFATUNBI AJAKAYE EWENJE TRADITIONAL HERBALIST. FOR ALTERNATIVE MEDICINE THERAPY..WHY HIDE YOUR PROBLEM??? CALL THIS NUMBER IF YOU HAVE ANY PROBLEM OR WHATSAPP+2348075654052).. THIS IS REAL TRY MY FATHER WITH SMALL MONEY YOU WE THAT IS REAL (08075654052). am tunde son of Ifatunbi Ajakaye of ijebuland am here to tell people about my grandfather what do you really need?(1)You want to be rich. (2) if you need (oshole market) (3) if You need (oshole yahoo) if you need (oshole for anything) (4) if you need (ogun own) (5) if you have rich before that you didn't have money again (6) if you are looking for star (7) if you (ogun ibo) (8) If you want a child. (9) if you have promise an fail (10) if you always have bad dreams. (11) You want to be promoted in your office. (12) You want women/men to run after you. (13) desire due to low reaction. (17) if your menstruation refuse to come out the day it suppose to come or over flows. (18) if your work refuse to pay your salary, people owing you?. (19) solve a land issue and get it back. (20) Let people obey my words and do my wish. (21) Do you have a low sperm count. (22) yahoo that want to do spiritual. (23) people that need fact money. (24) If you are pastor that looking for star. (25) If you doctor that looking for oshole aworo (26) IF YOU ARE THIEF THAT YOU NEED SPIRITUAL POWER (27) IF YOU ARE GIRL THAT YOU DOING ROSSY LEAVE (28) If you are Political that you need power that you we use to enter. A LOT of people have been successful working from this man. Don't use some others you've tried before to judge this one. Remember, you've to give it a try before judging. Give a chance and see where it goes.Well this is the unique opportunity for you to talk to us on Dis number (+2348075654052) now, try my fa
    • Onoja commented
      Admin @LadiSpeaks...youd have to see to this o
      Wow, this is it
    thanks for the tips
      nice tips
      Very useful
    Useful tips. Thanks
      very usefull
      Useful tips . I have learnt some things
    Please what I observed is that since I started using 64 gig, my any pictures or video snapped or recorded on the phone is not recorded and even if it does it corrupt by the time you are trying to check the pictures... I use tecno l9+... Reply will be appreciated
    • Onoja commented
      You're using a memory card not propey formatted to the phone.
    please google play problem is not connecting
    • Onoja commented
      Google Play is not connecting to the internet?
    mine am using 16gb memorycard if formatted it so many times as portable internal storage am unable to download huge games from play store or to run game with obb..its always crash and display storage full need to to uninstall some apps why all this happening and I love this device what's the solution..... please
    • Onoja commented
      Did you format it as internal storage?
    • shallabreezy commented
      yes I do I only see format as portable internal that's all... then I format it.... still yet storage full only I move files from phone storage to SD card I can't able to run huge games like Grand Theft Auto too
    Sorry to break this that SD card is counterfeit . Please buy a reliable compatible one from any Slot or Oraimo accessories store.
      What's more, at last play out a manufacturing plant reset, if none of the arrangements work for you. Keep in mind industrial facility reset will delete all information from your gadget thus, you should reinforcement and reestablish everything before playing out a processing plant reset. To do manufacturing plant reset go to Settings > Backup and reset > Factory information reset and select to delete all information. The principal thing you ought to do – ensure you are utilizing the first (Alaimo) charger that has accompanied the gadget for charging your cell phone. Essay Writing Service UK Cheap
      • Onoja commented
        LadiSpeaks Here you go again Admin
      there is a mistake in your spelt. Oramo <br />
      • Onoja commented
        He is correct with his spelling. You got it wrong
      Nice 1 there thanks for the tips
        Great work you're doing Phillip. God bless you
        Amen, thank you sir
        • Onoja commented
          Ywc, lol. I'm not sir, i'm a female
          Lol.
        please i have a problem.. i can't slide down my notifications bar unless it is in lock screen..<br />
        phone is tecno k7
          what is cause of System UI stopped?
