  • Camera app not working error fix All
    Hi T-fans,
    The following 7 Steps will fix camera app not working notification on Nougat 7.0 & marshmallow 6.0 Android phones.
    Try below given possible solutions to fix “Unfortunately, C
    amera has stopped” on android device.
    1st : Restart your android device
    One of the basic
    solution of any android problem, reboot your android device and check camera app is working on your device. Sometimes restart your device fix android phone error.
    2nd Method: system software update
    Update system in android 7.0 nougat to fix camera error
    Check latest software update available o
    n your android device. If an update is available then update your device. Updated devices may help fix android camera not working issue...
    3rd Method: Clear the cache of C
    amera app
    Step 1: Go to “Settings”
    Step 2: Under device section, tap “Apps”
    Step 3: Scroll down until
    seecamera and tap “Camera”
    Camera app not working android phone
    Step 4: Touch “Storage”
    Clear cache of camera app in 7.0 nougat
    Step 5: Tap “Clear cache”
    It will clear
    cache of camera app in android device.
    4th Method: Force stop camera to fix camera app not working android device
    Settings > Device > Apps > Camera > Force stop
    5th Method: Use safe mode to check any app cause problem
    Step 1: Press & hold the power button o
    n your android phone
    Touch Power off button to use safe mode in nougat 7.0
    Step 2: Touch & hold the power off button
    You can see this message: “Reboot to safe mode”
    Reboot to safe mode android 7 to fix
    camera issue
    Step 3: Tap “OK”
    Your device will restart in safe mode. You can see the “Safe mode” icon at the bottom side screen. Now check your device camera working fine, if working
    good, then any third party app causes this problem of camera app not working android. Uninstall recently downloaded app one by one and check camera error solve.
    6th Method: Reset app settings in android 7.0 nougat
    reset app preferences to fix camera app problem
    Settings > Device > Apps > More > Reset app preferences > Reset apps
    This reset app preferences setting will disabled apps, background data restrictions for apps, disabled app notifications, any permission restrictions and more.
    7th Method: Factory data reset android 7.0 Nougat
    Step 2: Under the
    personal section, tap “Backup & reset”
    Step 3: Tap “Factory data reset”
    Reset nougat device to fix android phone camera not working
    Step 4: Tap “Reset phone”
    Step 5: Tap “Erase everything”
    This factory
    reset android phone will delete all your personal information and downloaded apps from your device.
    If none of the above
    methods
    worked for you then you should download camera apps from Googleplay store to take photos or selfie
    on your android phone or tablet devices.
    End the list of troubleshooting steps to fix camera app not working android phone or tablet. Don’t forget to mention which method worked for you.
    Knowledge is power, they say. Thank you
      watch full movie deadpool2 free here>>>>>> http://movies2watch.stream/deadpool2/
          Informative
            Ma caméra ne marche pas toujours, je fais comment
              Thanks a lot, you have shared most wanted information for lots of Android user.
              Just check-it-out another great app, Moviebox to watch/download movies & tv series on smart phone for free.
              MovieBox Download for iOS & Android Running Devices. Movie Box app ready online & offline for your iPhone,iPad,iPod,Android & PC
              • T_101086070709 commented
                Moviebox app is not available in Google Play, How can I download to my Nova 3i ?
              I bought techno wx3p last week and the camera seized three days later how van I fix it now
                I have tried that on Techno Spark Plus but its not working still.The flash light and back camera is nit working
                  Kindly take you phone to the nearest Carlcare service centre.
                    Great guide, if you follow it properly then your problems can be easily fixed!
                      those the new update of tecno x have issues?
                        Originally posted by lummyfinest
                        Hi T-fans, [ATTACH=CONFIG]n194229[/ATTACH]
                        One of the basic
                        amera app
                        It will clear
                        camera issue
                        Step 3: Tap “OK”
                        Step 2: Under the
                        This factory
                        methods
                        • 08066794645 commented
                          My pouvoir 2 pro camera is worse than I expected, I think upgrade should include camera quality to justify the 13 mp so claim. For now even infinix 8mp is far better than the 13 mp of the pouvoir 2 pro. I am regretting not getting value for money in this phone
                        Great! thanks for sharing.
                          my shuttle icon is upside down
