  • SPOILER ALERT ON THE CAMON X PRO Nigeria
    After the latest software update on my case x pro, it hots up often and the battery drains so fast... TECNO Mobile..What is happening here!!!!!!!!!!!!!!!!
    same here
      when did u update n did they restore font manager??
        this issue has already been resolved earlier please...provided youve just done the latest update ... Factory resetting ur phone after backing up ur files resolves the overheating and excessive battery drainage issue...
          Solution to heating up and battery drain! Goto setting and select apps, then special access, select notification access and switch it to off for all apps! Your battery will last as expected while operating with normal temperature!!
            Please update your phone master app also, it will help and charge faster
              Have you try to update your phone master app.if no do so and see what happen next.
