  • Font for tecno camon 11 pro Nigeria
    Please why are the fonts not showing on Hi themes??? What happened to them???
    Tecno Mobile stole them. You'll find them on other phones like iTel, infinix and Samsung. Try buying that if you want fonts.
      They were removed when the recent updates were installed, but the TECNO team are working towards restoring font on your device, kindly be a tad bit patient sir.
      Thanks for using TECNO Mobile.
        They were removed when the recent updates were installed, but the TECNO team are working towards restoring font on your device, kindly be a tad bit patient sir.<br />
        Mr please respect yourself did you work in tecno company <br />
        please let tecno mobile answer that please
          I too need the fonts.what happened
            Why were the fonts remove in the first place? Now we know you guys removed the deliberately. It's been months since you removed the fonts and ha e sent many updates yet you have decided not to include the fonts. common fonts o, you guys can't replace.
              I need the fonts o
                why is there no version updates for CF8. that camon 11 pro. I want to upgrade to from 8. to 9... I need upgrade. Tecno or we are going to leave the mobile phone
