  • Camera issues Nigeria
    after my recent upgrade, my Camon x camera doesn't save pictures again, can anyone help?
    Check your phone for update, if there's none, take it to carl care
      Common reasons for this cause includes: Low storage space, Cache is full, Corruption in your SD card, Issues with your phone.<br />
      Try the following<br />
      1) Reboot your phone to see if it helps<br />
      2) Check your storage<br />
      3) Remount your SD card<br />
      4) Clear your camera cache or gallery cache data<br />
      5) Try an SD card recovery if it appears corrupt
        and before i forget, try an update of your device
          Hi
            the same problems ,,I have done everything listed here yet no remedy,,I thinks its from the upgrade. tecno pls if you don't have a good reason for upgrade don't send one,,you are causing problems on every new upgrade.pls do something.
              You might have to back up your device and perform a factory reset, others updated and did not have this issue. <br />
              In other to make sure back up perform a factory reset and please give feed back on how it goes. <br />
              Thank you.. <br />
