  • How To Fix Hotspot Issues On TECNO Devices Nigeria
    Good day T-Fans I trust you all are having a good day coupled with the continous rainfall, anyways today I will be addressing an issue, this complaints have been flooding TECNO spot for a while, now while the solution to this problem will be provided, I can't guarantee it will work for all users, but should in-case it does not work for you, kindly visit the carlcare center closest to you.
    Most T-Fans have been making complaints about their hotspot turning of by it self whenever they put it on and I also have a caption below of a brother whom have made same complaints to me, just so you know this software related issue is not peculiar to TECNO devices alone, even Infinix users are affected by it.
    Most times this hotspot, WiFi and bluetooth issues are caused by third party applications installed or updated on our devices like; babel font
    HOW TO FIX HOTSPOT ISSUE ON TECNO DEVICES
    • Go to your phone settings
    • navigate your way to "Apps" and click on it.
    • Now tap on the three dots on the screen beside the settings symbol and a pop up will appear like the one in the caption below
    • as you can see there are two options being displayed there, so just tap on "reset app preferences".
    • once done, reboot your device and turn on your hotspot.
    Should in-case the problem does persists; go to "Settings" locate and Click on "Apps" show system apps and reset "OOBE" if that does not work locate "Babel Font" and uninstall updates made on it..
    but I am certain one of them will work most especially the first step, it worked for me and other users I have tried it on.
    Don't forget to share your feedback here also ask questions too and I will be here to help out, thanks for using TECNO Mobile
    Thanx, i have tried the first option didnt work, help me on how to reset OOBE on the second option, for i have located it but cannot find how to reset it.
    • Tamara99 commented
      Hmm
    Did you reboot your phone after carrying out the first step ?
      That's good
        Make sense. Nice one
        all good, this shoul bring a stop to the topic of hotspot not functioning
        • Onoja commented
          Honestly, Now they know what to do if this kind of issue should come up
          And it works...
        • enoch273 commented
          Thanks a lot guys
        nice one
          Glad a solution has been provided
          He did a good job
        • Onoja commented
          Yeah, big thanks to him
        Originally posted by nas View Post
        That's good
        Thanks boss.
          Well done
        Thanks dear, I'm looking forward to their feedbacks.
          Hope you got good feedback
        Thanks sir, glad you like it.
          Originally posted by bourdillon View Post
          nice one
            Thanks this really help solve my hotspot going off. Good job
            • Onoja commented
              Nice one, positive feedbacks already
              Thanks for the compliments
              This is nice
            Mine doesn't go off, but hotspot can't be detected by any windows device. I tried all above but nothing. I can use USB but not wifi. Worse still I hoped the new update for Camon CX will fix but up to now my phone has not received the update.
              Go to the Bluetooth, WiFi or hotspot app and clear cache and data sir, after which reboot your device
                Thanks Moderator
              • Onoja commented
                You all are welcome, thanks to you too
              Sorry about that sir. Will definitely work on a solution for that, by the way which of the windows version have you used it on ?
