  • How To Use Harassment Block Feature Directly From TECNO Camon CX Dialer Nigeria
    Good day T- Fans, hope you all are having a wonderful day? I won't be taking much of your time as I will be sharing another revamped feature I found out on the TECNO Camon CX, Today I will be sharing with you how to block call and sms directly from camon CX dialer without the use of a third party app.
    I was playing around with my TECNO Camon CX as usual when I found another cool revamped feature on it, The reason I use the word revamped is cause that same feature is available on all TECNO devices running on HiOS, but you have to go through the Hi Manager App to get to it, but on the TECNO Camon CX you can utilise this feature directly from your dialer.
    How To Use Harassment Block Feature Directly From Camon CX Dialer. To Block Calls And SMS
    We all know how wonderful our network providers in Nigeria are,first they will automatically and forcibly subscribe you to one of their plans you know nothing about and start bombarding you with series of messages and just when you think they are done and you are expecting a very important call, they come to your aid once more and below is how to put them in their place.
    • Click on your Camon CX dialer and tap on the three little dots below the far left corner
    • an option should display as shown in the caption above, tap on "Harassment Block" and another box will display like the one below.
    • From the screenshot above you have the option to either block calls, SMS OR even both, so swipe to the left to "Blacklist" once on blacklist click on the (+) Icon and a prompt like the one below should pop up
    • from the caption above we can either blocks from number that are saved or check our call logs to block unsolicited calls from network providers and if you don't want to be disturbed, this feature can also be reversed
    If you do have any question/feedback, do use the comment box below and I will be with you shortly, thanks for using TECNO Mobile, do have a wonderful day.
    Nice feature! Thanks for informing us about it.
    • transformer commented
      Thanks alot
    • Mormony commented
      Very nice
    • Mormony commented
      Very nice
    Thanks baba
      It's nice mehn
    • Mormony commented
      Ur welcome
    it's also available on phantom 6Plus running on OS 7.1.1
      Nice
      Thats great
    • Mormony commented
      Very good
    Nice feature. I'll have to block this Airtel people calling me anyhow.
      Those people can be annoying
      So needed
      As In ehn
    Yes Sir
      Yes it is
    Exactly, thanks for the feedback Sir
      It is good news
    how much
      How much for?
      For wat?
    Thanks for the info..
      Its a nice one
    bro im so much loving ur reviews
      very well
    • enoch273 commented
      Thanks sirs
      Very well
    ok
      Is that all?
    thanks you so much
      Its a good info
      so nice
    thanks for the tips
      So helpful.
      Very helpful bro
    Thanks for the Info OP
      good information
      E make sense
      thanks sirs.
    Hello Enoch. Pls how did you change your font, I can observe a cool font used in ds screenshot
      I think its In the settings
