  • Rebooting problem Nigeria
    please, my CX air started rebooting itself today. it went on for over 6 hours without starting. now that it's on, my apps have crashed... what do I do?
    like all your apps are not functioning anymore?
      If there is any app you installed before this started kindly uninstall it now.<br />
      If nothing happens please backup first then restore factory settings quickly back to default.
        did it just start rebooting on its own?
          No... I don't have any other app asides my social network apps. <br />
          All my apps except WhatsApp aren't responding again
            Sorry about that Sir, make a backup of your important files and factory reset the device.
              If it is not starting the only way u can do a factory reset is by rebooting into recovery, power off the device, then power it on by pressing the power button and the vol+ button, once it is booted into the recovery mode, wipe data and cache then reboot, the first boot might take sometime so be patient.
                thank you so much
                  thank you so much
                  Have the apps started working?
                  • the_olufolake commented
                    yes. I took the phone to Carl care
                  if you just update your phone, factory reset it but if not, then check out the app you installed last and uninstall it or then and reboot your phone
                    As for the Whatsapp that is not working, you can uninstall and download another. Sorry for the inconveniences.
