  • How can I solve hot-spot and Bluetooth.. And Bluetooth tethering in tecno c 9+ Egypt
    Now I have problems in activate bluetooth
    And hot spot
    I can't turn it on
    It's automatically turned off
    try checking if there is any update to fix bugs
      reset your smartphone by formatting it
        I think it's a sign that you really need to update your device. Try updating it if there's any available but if not available then try flashing the device
          Welcome to Carlcare Customer Service Please remove the MEMORY Card and try again. If the problem persists, please factory reset to your device and keep all your personal data on an external MEMORY for not missing it.
            First Remove your memory card, then restart your device.
            Looking for Best Headphone AMP under 100 Dollar. FiiO E6 Headphone AMP Behringer HA400, Creative Sound Blaster E1 Portable Headphone Amp.
              reset your phone, then it will better.
              Best Car Speakers is a difficult task since it might look. This is only because they truly are various brands which are available in the
                Don't reset your phone. Just delete data of Babbel fonts and disable it. Had the same problem and fixed it this way!
