  • How to use SD Card as Internal memory on Camon CX Nigeria
    Hello TFans
    The last Camon CX system update comes with a feature that allows you to adopt your removable micro SD installed on your device to be used as internal storage. This way you can have more space for applications installation and multimedia but we notice majority of Camon CX users on this platform are not aware of it or are finding it difficult to set up their SD card as internal storage.
    In this tutorial I will be showing you steps on how you can adopt your SD card as internal storage. The first thing to do is to backup all your data on your SD Card to your PC or transfer it to another device because your Sd card would get formatted during the process. Step by step procedure
    1. Insert an SD Card inside your device and wait for it to get detected.
    2. ‎Now open your settings app
    3. ‎Scroll down and go to Storage H
    4. ‎Tap on your SD Card
    5. ‎Choose format as portable and tap format to continue.
    6. ‎wait for the process to complete this might take few minutes.
    ​ You can now successfully move your applications to SD Card. To switch between SD Card and internal... choose your preferred storage and migrate data. If you're having any problem with the procedure you can drop in the comments section.
    why can't I update my system?<br />
    since last year precisely October, each time I check system update, it keep on telling me your system is up to date
      Thank you for the info bro. This shall help lots here
        Yeah nice information
      Please check you network connection or just take it to Carlcare office <br />
      Originally posted by emmaone
      why can't I update my system?<br /><br />
        • FellaLawson commented
          why you dey show us your face?
        • Tamara99 commented
          Interesting
        cool
          So cool
          Really cool
        Please my tecnoL9plus has stopped screenshoting and I've tried everything including swiping with 3 fingers.... Please any ideas...
          reset your phone
          factory reset ....
        I tried to convert my SD card to internal memory but at the end of the process the 32G memory card was corrupted.
          the memory card was probably a fake. Try it with another memory card.
        I did all these processes correctly but after some few days my SD card got corrupted .......pls help me out
          My Camon cx do bring update but just decide not to do so, cos it won't corrupt my phone.
            Did you root your device?
            Can i use this for my cx air
            Nice info
              am new
                Hello. <br />
                After the process I can't use the phone internal memory. Help please.
