  • How to Use the Phone Master on TECNO Camon CM All
    Hi T-Fans,
    In 2016 when TECNO Mobile introduced the Hi Manager alongside the customized UI interface, it was greatly received because up till then, people depended on 3rd party apps to organize their device.
    But with the advent of the Hi Manager, it meant one less app to download. In 2017, an update was released on TECNO Mobile devices that renamed Hi Manager to Phone Master… also, more features were added to the app.
    Today, I would be showing you how to use the Phone Master app on your Camon CM:
    LIGHTENING BOOST: This is used to clear your RAM when your device is running slow due to too many open apps. It’s one of the fastest method of freeing your RAM.
    CLEAR TRASH: During the usage of your device, apps creates error logs, dump files and caches and they are stored up and would take up a lot of memory over a period of time. This function is used to clear all this error logs, dump files and caches and left over APK files stored by different apps on your device.
    DATA TRAFFIC MANAGEMENT: This function has a lot of sub features like;
    • Data Plan: Used to set up your data plan limit for the day, week or month. This would ensure you are able to plan your data usage for the set time.
    • Click image for larger version
    • Data Limit Exceeded Notification: With this feature, you can set your device to notify you when you have almost exhausted your data.
    • Automatic Network Off: Put on this feature to switch off your data once your data limit is reached.
    • Network Management: This is used to control which app access to your data. All installed on the device can be internet activated or deactivated. You can also use it to know each app’s data usage.
    • Status Bar Network Speed Display: This enables/Disable the status bar used to monitor browsing speed
    • Data Traffic on Notification Bar: This when enabled shows the Daily usage of Data and how much data is remaining.
    HARASSMENT FILTER: This is used to bar SMS and phone calls you don’t want to receive on your Camon CM. It could also be used to Blacklist numbers too.
    APP MANAGEMENT: This has the option to uninstall apps that are not frequently used. You could also adjust your app notification settings under this menu.
    DEEP CLEAN: This menu further digs into your device and cleans heavy files. This is only advisable when you have done a full back up on your device. But it sure does a good job at cleaning your device.
    CLEAN WHATSAPP: This is specifically dedicated to the Whatsapp app. Since so much space is consumed by your Whatsapp due to the amount of pictures, videos and files exchanged on this app, this menu helps put you out of this misery.
    FILE MOVE: This menu provides a one button click to move apps from phone memory to SD Card memory. Instead of going through the stress of locating files, pictures or videos under the File Manager, this option saves you all that stress. Everything is classified under their respective categories.
    PHONE COOLING: This menu helps kill apps which makes so much use of the CPU, thereby reducing the temperature of your device.
    AUTO-START MANAGEMENT: There are some apps that start up with your device when you switch it on. This menu helps you to monitor such apps. You can either increase or decrease the number of these apps with this menu.
    FREEZER: This menu is particularly useful when you don’t want to uninstall a rarely used app, yet you are running out of space. You can just freeze the app and to create more space and unfreeze it when you are ready to use it.
    SLIMING: This is similar to the deep clean and the clear trash feature. You can say it is the combination of the two. It is used to create more space.
    i must admit that i am using the app and it helps me so much. Much thanks to Tecno Mobile
      Me too it helps much
      wonderful app
      Very useful app.
    how to updatr phone master in the camon cx??????<br />
    update error
      update via playstore
      go to your app store if any update is available
    Please I want to confirm if the screen is corning gorilla? You know it's difficult to know this because there is cover on the screen. Thank you.
      I dont think it is
      Yes it is
    It comes with a 2.5D Corning Gorrilla glass 2<br />
      I never knew it was gorilla glass
      Thats nice. WOuld be strong
      Its a nice forum
        Thanks for the info
          A very handy feature. Nice info
            Maybe not gorrila but I’m sure there’s some sort of other protection
              This app is of a good use kabisa. thanks goes to Tecno
                mine is still called hi manager, am using TECNO l9 plus
                  Nice info
