  • Why not follow up??? All
    Make sure you fix the software ( phone Master). The update does not make a mistake. Or introduce the correct link. Why not follow up... Click image for larger version
ID:	14976 \ud83d\udc46\ud83d\udc46\ud83d\udc46\ud83d\udc46\u d83d\udc46
    TECNO needs to take note of these complaints
      There is an existing phone master app that's why u can't install it again. So u need to go to settings and uninstall the existing app before u can install the current update.<br />
      Download ESexplorer for u to see the list of ur apps then u wil see that this particular apk is Corrupt that's why u r getting this response.<br />
        Originally posted by AUSTINDON
        There is an existing phone master app that's why u can't install it again. So u need to go to settings and uninstall the existing app before u can install the current update.<br /><br />
        Download ESexplorer for u to see the list of ur apps then u wil see that this particular apk is Corrupt that's why u r getting this response.<br /><br />
        Hello. My phone is not rooted, I can not erase it.
        • AUSTINDON commented
          I know it's not rooted, go to app management and uninstall the recent updates then it wld go back to the original phone master when u bought the phone.<br />
          That's what I mean by uninstalling.<br />
          Once u click it, it will ask u if u want to uninstall recent update, click yes and continue.<br />
          There is an existing phone master app that's why u can't install it again. So u need to go to settings and uninstall the existing app before u can install the current update.<br /><br /><br />
          <br /><br /><br />
          Download ESexplorer for u to see the list of ur apps then u wil see that this particular apk is Corrupt that's why u r getting this response.<br /><br /><br />
          The phone recognizes this software as a system software. Uninstall option is only force stop. And I have not upgraded so far. It's the one that was installed on the phone from the beginning.
