  • USING THE FACE ID TO LOCK APPS ON CAMON X AND X PRO All
    Hi T-Fans,
    One of the juicy functions newly introduced into TECNO Mobile’s latest devices, the Camon X and X Pro is the FACE ID. The Face ID is a new technology and TECNO Mobile is the first mobile phone company to feature the technology on a mid-range device.
    Now, this feature is not only useful for unlocking your device in general, it can also be used to lock apps individually to prevent invaders from intruding into your privacy.
    In this tutorial, we would be talking about how to set up the Face ID to lock apps on your Camon X. It is important to note that this feature can only be activated with the help of Phone Master App. (v2.5 and above).
    All you need to do is follow the following steps:
    Step 1: Launch Phone Master App.
    Step 2: Select the Toolbox option at the bottom of the screen.
    Step 3: Select App Lock.
    Step 4: Create a lock pattern as a back up in case there is an issue with your FACE ID.
    Step 5: Select the apps you want to lock…
    That’s all!
    faceid is not there for Camon CM .
    • Tamara99 commented
      I dont think so too
    please when is xpro coming out
      They just released it
    please when is x pro coming out
    • Kaykerry commented
      It is out please
      They actually just released it
    Originally posted by Kaykerry
    [ATTACH=CONFIG]n191799[/ATTACH]<br />
    Hi T-Fans,<br />
    One of the juicy functions newly introduced into TECNO Mobile’s latest devices, the Camon X and X Pro is the FACE ID. The Face ID is a new technology and TECNO Mobile is the first mobile phone company to feature the technology on a mid-range device.<br />
    Now, this feature is not only useful for unlocking your device in general, it can also be used to lock apps individually to prevent invaders from intruding into your privacy.<br />
    In this tutorial, we would be talking about how to set up the Face ID to lock apps on your Camon X. It is important to note that this feature can only be activated with the help of Phone Master App. (v2.5 and above).<br />
    All you need to do is follow the following steps:<br />
    ​<br />
    Step 2: Select the Toolbox option at the bottom of the screen.<br />
    [ATTACH=CONFIG]n191798[/ATTACH] ​<br />
    Step 3: Select App Lock.<br />
    [ATTACH=CONFIG]n191796[/ATTACH]<br />
    Step 4: Create a lock pattern as a back up in case there is an issue with your FACE ID.<br />
    [ATTACH=CONFIG]n191795[/ATTACH]<br />
    Step 5: Select the apps you want to lock…<br />
    [ATTACH=CONFIG]n191797[/ATTACH]<br />
    That’s all!
      may 11 or 12
        can the face lock work on spark k9
