  • camon x problems Kenya
    who else has got this update notification from camon x? then how does someone change the storage from internal to external sd.my photos are directly saved to the phone and music which i dont like
    same got the update and phone started misbehaving.. I had to uninstall everything
      U need to format ur mcard as internal storage.
        You'll have to format your SD card as internal memory.
          Tecno camon x misbehaving after updates expecially any app protected by phone master e.g whatsapp
            my camon x cant update it keeps telllng me WAITING FOR WIFI AND CONNECT OTA WHEN BATTERY IS LOW
