  • HiOS 3.3 Review on the Camon X and the Camon X Pro All
    I would be reviewing the latest update on TECNO smart phones, the HiOS 3.0 and especially on TECNO Camon X.
    As we all know, the TECNO HiOS is TECNO’s customized User Interface, UI which runs on all TECNOsmart phones
    released in 2016 and for those who remember well that the first smartphone to feature this UI was the TECNO Boom J8.
    The HiOS have come a long way starting from the first edition HiOS 1.0 which was released in 2016 to the HiOS 2.0 which was released last year. The growth has been quite impressive over the years.
    Here is a snapshot of the App tray on the Camon X HiOS 3.0
    As seen clearly, the app icons are smaller when viewed on the tray.
    I would be taking a look at how incoming calls are displayed on the HiOS 3.0 versions. In the HiOS 2.0, it allows for the receipt of calls while working on other things. It also allowed that the location of the caller be shown, however in the HiOS 3.0, while it retains the dual functionality, it eliminated the location display and shows the caller’s network instead. It also directly tells you which SIM is receiving the call as also shown in the screenshot below.
    Power Saving Management
    It is no longer news that the latest
    update has removed the Ultra Power Saving Mode from TECNO devices, why this happened would keep being a mystery although it is known that Android stock devices do not have the Ultra Power saving mode. This implies that unlike the HiOS 2.0, the HiOS 3.0 does not have the Ultra Power mode but has the Battery Saving mode instead. This mode is designed to help save battery and make the device last longer while being used fully unlike the Ultra power saving mode which does not allow any usage other than basic usage.
ID:	15542Click image for larger version
    The Phone Master allows for more complex management of power; you can always toggle off brightness, wifi, location, Bluetooth and even vibration on tapping of the screen. You can play with all forms of power saving options on the device using this Advanced settings.
    File Move to SDCard
    The other HiOS version does not have the ability to move your files to SDCard from the Phone Master directly. The HiOS 3.0 on the Camon X does allow this. This means that you can move your apps to your SD Card. We all know this feature was discontinued originally on the Android Marshmallow by Android themselves but HiOS allows you to do this using the Phone Master on the device.
    So, if you are willing to move apps and files to SDCard, you are safe and secured.
    will camon cx get the update?
    • LadiSpeaks commented
      You should update your device
      It should
      Yeah
    Actually the latest version of phone master is taking care of all features we missed on the recent update plus other features we didn't have like moving apps data to SD card
    +255744123365
      Nice
      This is good
    Good one.
      Very good
      good
    I would love to sell my Tecno camon x for 55k it still new and all the things are still intact
      What happened to it?
    u can reach me on 08181840214 $ 07083361851
      when is the update being rolled out in kenya
        pls how much is camon xpro in Nigeria
        • Kaykerry commented
          its dope for that price
        how much is camon x
        • Tamara99 commented
          N77,000 for pro
        nice
          please somebody help me, my Cx Air don't enter Ultra power saver again. what might be the course, if I click the Ultra Icon, it takes me to the home screen
            The feature has been removed from the latest update
          help, so I gave my brother my tecno spark 7 to use for few months after I got it newly and before I took it back from him he restored factory settings and after that time it's been having one issue or the other... some applications don't respond,system UI isn't responding, sometimes my apps close on their own... please why is this happening and what can u do???
            Factory Reset also
            Carlcare should also help too
            do the reset again
          hi
            I wan na sell my techno k7 with 1gb ram
