  • Using The OTG Function On The Camon X And X Pro All
    Hi T-Fan,
    The OTG function is one of the most underutilized
    functions on a mobile device. Some people that even know how it works have a very shallow knowledge of its functions. Some even think it's just used to charge another device. Some don’t even have an idea what it is used for, thereby ignoring the feature totally.
    In this article, we would be examining the many functions of this feature on the Tecno Camon X and X Pro.
    First what is OTG: It simply means On The Go. It is an add-on feature that enables easy navigation on a mobile device. The OTG function is made possible by a phone attachment called the OTG cable/cord/dongle. All you need to do is attach the cord to your device then attach your external device to the cord. Now, there are a couple of things you can do with the USB OTG and today, we would be highlighting them.
    Charging Another Device: This is the function most people are familiar with. You have a device with a low battery, you just connect it to an OTG enabled device and instantly, you have your battery charging. This function might look a bit primitive but can prove to be a live saver when you really need to extract an important info from a dead phone.
    Connecting External Mouse: This is one of the cool functions of the OTG. Imagine you have a cracked screen, or some parts of your screen is not responding to touch. All you need to do is connect the OTG cord to your device and connect the USB mouse to the OTG cord and instantly you see a mouse on the screen of your phone.
    Connecting Flash Drive/External storage: This is also a live-saving function in a situation where the information you want to retrieve is on external storage or on a flash drive. The phone would be able to read, modify, add to or even delete the contents of the external storage.
Name:	android-basics-check-your-phone-for-usb-go-support-connect-flash-drives-control-dslrs-more.w1456.jpg
    Connecting External Keyboard: This is quite similar to the external mouse function. After connecting the external keyboard to the OTG cord connected to the device, you can now type on the keyboard and it would appear on the phone screen. This is particularly useful when you have something voluminous to type and the phone screen is not just enough or some parts of the screen is not responding.
    Connecting External GamePad: This is particularly useful to gamers who love to play games on their mobile device. The truth is, sometimes, the screen is not just enough. Just connect the USB gaming pad to the OTG device and you are good to go!
    Connecting To Printers: This is one very cool aspect of OTG that really appeals to those in the business world. The OTG function allows you to print directly from your mobile device! This is useful when your PC is not readily available and you urgently need to print a document.
    U r missing out the most important aspect of the function which is printing direct with a printer cable.<br />
    I do print documents with HP printer installed in my phone.
    • Kaykerry commented
      Thanks for the correction..it would be added ASAP
    How about the internet connexion 3G+ dongle ?
      This is jaw dropping. Never knew it has so many functionality
        Nice one.. make sense
          Cool
            please there is always a pop up on my camon cx that "connect to OTG" which makes my phone freezes & goes off every 10mins<br />
            please I seriously need ur help I want to stop using Tecno
              I am also having the same problem
                Cool feature..... I like dat it can be connected to the printer
                  Yeah.... Gamepad
                    Originally posted by tolugaruba
                    Cool
                    Same problem here bro<br />
                    Yet the OTG can't be displayed
                      Does it come along with the phone package or you'll have to buy it
                        You have to buy it sir
                      mine connects automatically which makes my phone #camon x pro not to charge unless i swtch the phone off
                        Cx air
                          Wow... thanks for the elaboration. Never knew OTG plays a lot more functions.
