  • How to use different fonts on Tecno devices All
    Hi T-Fans,
    Without much further ado
    , I will just go straight to the steps
    step 1... download
    ifont via Playstore or any other font app of your choice
    open the
    ifont, download any font style of your choice
    step 2..open file manager
    , locateifont folder, click on it, click on cache folder, you will see the downloaded font style you downloaded via ifont app
ID:	16258 Click image for larger version
ID:	16259 Click image for larger version
    step 3..move the folder to
    lovely fonts folder
    Note
    : Some of you wont see the lovely fonts folder on your file manager, so what you have to do is to open Hi theme-->discovery-->font-->then download any font, just any font to bring out the lovely fonts folder on your file manager.
    step 4..open lovely fonts folder, locate latin
    paste the moved ifont->cache->downloaded font style folder there. Then you are good to go\ud83d\udc4d
    final step..goto settings->themes and lock screen
    select my fonts,u will see the font style you want to use
ID:	16264 Click image for larger version
    if you
    don't get it right, ask me questions.
    Goodluck.
    OK.. This is very good.. Kudos.. Worked like you said to would
      Thanks,am glad it did<br />
        very helpful
          Wao! worked perfectly well, thanks!
            wooow....rly worked thnks much
              you are welcome
                Am having issues opening my fonts. The font manager keeps stopping. How do I rectify this error. Am using a Camon X Pro
                  Does this work on phantom8?
                    yes it does
                      font manager as in,in the Hi themes section or the settings section?
                      • Namdie commented
                        in both.... I'm using the camon x pro as well
                      • T_109007828655 commented
                        I have an issue too I cant see the font style in themes and lockscreen but they are in lovely fonts folder under latin but when i click its unsupported kindly help quick i wanna change my font
                      that was Usefull tank You !
                      دانلود جزوه ریاضی عمومی 1 دانلود از یوتیوب خرید چوکر خرید اینترنتی مواد آزمایشگاهی
                        how bout making sure the ringtone does not change each time u switch off the phone ?
                          Worked perfectly.......Thanks!!!! aside from ifont, which other font app would you recommend?
                          • Tamara99 commented
                            I want to know too
                          Cool feature
