  • Change in state of camon x pro battery Nigeria
    this battery sucks this days I tell you I'm beginning to hate this phone I swear
    09055057854<br />
    message me on Whatsapp bro<br />
    let me give you some solutions if it lld work
      sell am give me I will change the battery
        no bro thanks
          Hi crownz
          I’m sorry about the issue you are having
          Here are some fixes you can try
          1 Update your phone software to the latest version.
          2. Update your apps via Play Store
          3. Perform a factory reset on your device
          4. If the issue persists, visit our service centers closest to you for assistance.
          Sorry for the inconvenience caused to you again. We will continue to improve, thanks for your support.
            what exactly is wrong with your battery? try making use of your battery manager to optimize usage.
