  • CAMON X problem All
    Hello Am from Ghana. My CAMON X with 16gb the storage space makes full too early all because the system apps only have taken half of the storage. Why should it be that way. And after u have installed apps it also takes like 40% of the remaining space which leaves u with few space left. So can't that issue be solved or resolved??
    Please use a suitable memory card.. The system files must be saved somewhere...<br />
    Please install the memory card as internal memory, set it as the default memory and move all your data to the memory card
