  • HOW TO SET UP FACIAL RECOGNITION FEATURE ON CAMON 11 PRO Nigeria
    Privacy and security are key elements in every mobile devices. TECNO Mobile decided to take it a leap higher with the introduction of facial recognition technology on the Camon X Pro. The facial recognition function on the Camon X Pro works pretty well but the Camon 11 Pro comes with a better facial recognition with a recognition rate of 500ms for faster and accurate unlocking.
    In this tutorial I will be taking you through step by step process of setting up the facial recognition feature on the Camon 11 Pro device.
    1. Launch Settings App
    2. Tap on Security & Location
    3. Tap on Face Unlock
    4. Choose Enroll Face Unlock
    5.Set up lockscreen and alternative security option( PIN or Pattern).
    6.Keep your face within the scanner (The process should take less than 5seconds to complete).
    Now that the scanning is completed, you can now proceed to unlocking your device with your face. Cheers
    The Face unlock Is Even the Front App A-Z
      definitely you use your front camera to set it up
    quite helpful tnz
      very helpful
    how to set WhatsApp on desktop on camon 11
      whatsapp on desktop or your camon 11?
    That's a great guide, i was looking for this because i am web designer in dubai and recently i am developing an application which requires facial recognition for its login.
      good luck on that
    Tecno camon i2x, font camera Edge detection have many problem. please fix it
      yeah it would be fixed
      definitely would be fixed
    Thanks for sharing
      educative article
    thank you for sharing...it helped...
      definitely helpful article
    Thanks for this
      article was quite educative
    quite helpful. thumbs up
      thanks
        since I updated latest version on my phone camon cx many of my application is not working please what do I do to rectify the problem I need a help
          the face recognition is shit, anybody's face can unlock the phone
