  • HOW TO HIDE AND UNHIDE THE NOTCH ON CAMON 11 AND CAMON 11 PRO Nigeria
    The Notch is a cutout at the top of the smartphone phone display. The notch design made it debut into the smartphone industry in 2017 and had since became a trend. The notch provides aethestic value to your device display.
    Few users may not like the notch and they may wish to remove it. With this guide, You can learn an easy method on how to hide and unhide the notch on your Camon 11 Pro device.
    The first step is to launch your settings app
    The second step is tap on the Display Option
    Tap on "Display Mode of Notch Screen
    Select your preferred mode. Cutout mode (Notch to Show) or the Full screen mode( Notch to Hide).
    You can also share your views on which mode you think is the best under the comment section.
    What about the font on LA7 that you people took away,when you asked us to update the device.And you even promised to restore it b4 2018 comes to an end.You are toying with us.
      i am sure they would bring it back
    helpful
      yeah very helpful
    that is not the issue...we can solve that without your help just fix the problem of fonts if you want to help or just shut it up
      i am sure they would bring back the fonts soon
    We don't care about the notch or not.. Bring back our fonts...!!!!!!!??
      they would definitely
    So then....? How is it attractive? Thats the innovation that all the engineers at Tecno can come up with? Don't be proud of it
      it is attractive actually
    where is font and mira vision ??
      they are bringing the fonts back soonest
    Thanks.. Make sense
    this feature is cool...
    Tecno the notch on my LA7 has been taking away after upgrading as you people instructed me to do and don't find it easy again to use my phone because I'm so fun of using it.Hoe can i get it back?.
      how can i use the AR emoji
        How can we do this for TECNO camp Cx pro please!!!... Some notifications of apps like Skype, kik aren't displaying unless you open the app... Please I need fix for this his!!
        • Kaykerry commented
          This feature is for Camon 11 and 1 pro for now
        the problem not for your device mny divece of tecno facing on this problem like k7 and mine w5
          The issue of fonts isn't Still fixed. Bring back fonts. Without it, everything sucks.
            they would bring it back definitely
          This is cool
