  • camon cx air hotspot goes off after 5 minutes Nigeria
    Hi, my phone hot-spot goes off after minutes. This started when I did the system update as recommended from tecno around September 2018. I've not been able to fix this issue since then after trying all possible solutions. Pls help out, it's becoming frustrating \ud83d\ude41
    Have you tried switching the settings that enables the Hotspot go off after some minutes of idleness?
      have been facing the same problem too since last year. Pls help with a solution
