  • HOW TO ACTIVATE THE ANIMATED EMOJI (ANIMOJI) FEATURE ON CAMON 11 AND 11 PRO Nigeria
    Hello T-Fans
    Do you wish to express yourself in a whole new way and have fun while chatting with your family and loved ones using the AR Animated Emoji (ANIEMOJI) feature on the Camon 11 and Camon 11 Pro.
    This feature allows you to record a 10 seconds video message with up to 9 animoji characters of your choice using the front facing camera. With the animoji character following your facial movements as it records your audio as well making it look as if you're talking. Here's how you can set up and create your own Animoji on your Camon 11 and Camon 11 Pro.
    FIRST STEP: SET UP
    Launch the "Settings app"
    Scroll Down to "System"
    Select "Language and Input"
    Tap on "Virtual Keyboard"
    Tap on "Manage keyboard" and check "Kika Keyboard".
    Go back to "Virtual Keyboard" , select "Kika Keyboard" as your default Keyboard app and activate it.
    You've successfully completed the first step.
    SECOND STEP: USING YOUR ANIMOJI
    Launch your "Chat App (WhatsApp, Messenger,IMO)" Start a new conversation or tap on an existing one.
    Select "Emoji Icon"
    Tap on "Animated Emoji Icon" at the bottom of the keyboard.
    Click on the "red circle" to record and click on the "red square" to end your recording.
    Tap on the "blue arrow" to send.
    If you're having any problem with the steps you can drop a comment below. CHEERS
    Chatting becomes more interesting with the animated emoji.. Awesome
      it is really awesome
      really interesting
      this is so unique
    please how do I draw on picture as you do so?
      i can't find the animated emoji icon on my own Kika keyboard
        follow the instructions
        make sure you read through the instructions throughly
      • TECNO SPOT NG commented
        Uninstall it and reinstall it
      same here
        This is great. Nice
          really nice
          really lovely
          lovely
        I'm telling you. People can express themselves more in a very cool way.
        Have you followed the instructions stated above?
        Originally posted by TECNO SPOT NG View Post
        Hello T-Fans
        [ATTACH=CONFIG]n291668[/ATTACH]
        FIRST STEP: SET UP
        [ATTACH=CONFIG]n291665[/ATTACH]
        Select "Emoji Icon"
        [ATTACH=CONFIG]n291666[/ATTACH]
        [ATTACH=CONFIG]n291667[/ATTACH]
        This is a very unique way in expressing oneself
          This will create more interaction with the phone. Thanks for this
            try to download touchpal, you are going to enjoy it so wela.
                I can't find the aniemoji icon on my keyboard
                  It works on Kika keyboard
                gud
                  i can t find animated emoji icon on my camon 11 pro. please help
                    If the Kika keyboard already on ur keyboard, uninstall it and reinstall it
