  • how to fix some problems of camon cx air Nigeria
    plz how do i solve the problem of the error system ui is not respnding and also the problem of my hotspot turning off on its own am using a tecno camon cx air
    The system not responding is very normal in Android devices
      For the hot-spot, you'll have to take it to carlcare
        Visit Carlcare. And make a complaint.
          update your device and carry out a factory reset on it
