  • sensor pouch problem Nigeria
    my smart cover doesn't work with my phone after the update and I don't know why? please who can help me?
    Dear Adesojiagbaje,
    Your complaint has been noted and would be worked on. Please also use the feedback app on your device to make the complaint
      take your device to the nearest carl care center to you.they should be able to help
