  • HOW TO ACTIVATE ANDROID 9 PIE GESTURE NAVIGATION ON CAMON 11 PRO Nigeria
    Enjoy immersive viewing pleasure on your Camon 11 and 11 Pro by switching to Android 9 Pie Gesture navigation that has been made available on the Camon 11 and Pro it allows you to operate your device fluidly and intuitively through the interface compared to On screen navigation button we have been used to.
    This feature allows for better viewing experience while running your favourite applications and games, giving you more screen space and also lessen distractions.
    To enable the gesture navigation Simply launch your settings app
    Tap on System navigation
    Click on Gesture navigation to activate it.
    Follow the same process to switch back to onscreen navigation.
    Note: Slide up at the edge of left area of the display to enter Recent.
    Slide up at the edge of center area to enter Launcher.
    Slide up at the edge of right area to Back..
    You can ask questions below.
    We have the already in the camon x pro... Kudos
      please,.....i can't access the animoji features on my camon 11 pro device
        .....what do i do?
          .....what do i do?
          you will need to install this =
            .....what do i do?
            you need to install this =
              I don't like the function, no way to do multitask
                pls my call app do not support always ask on sim selection
                  Enjoy immersive viewing pleasure on your Camon 11 and 11 Pro by switching to Android 9 Pie Gesture navigation that has been made available on the Camon 11 and Pro it allows you to operate your device fluidly and intuitively through the interface compared to On screen navigation button we have been used to.<br />
                  [ATTACH=CONFIG]n297257[/ATTACH]<br />
                  This feature allows for better viewing experience while running your favourite applications and games, giving you more screen space and also lessen distractions.<br />
                  [ATTACH=CONFIG]n297258[/ATTACH]<br />
                  To enable the gesture navigation Simply launch your settings app<br />
                  Tap on System navigation<br />
                  [ATTACH=CONFIG]n297259[/ATTACH]<br />
                  Follow the same process to switch back to onscreen navigation.<br />
                  Note: Slide up at the edge of left area of the display to enter Recent.<br />
                  Slide up at the edge of center area to enter Launcher.<br />
                  Slide up at the edge of right area to Back..<br />
                    hi
                      My phone do not store power for long it takes shortest time
                        when is the android 9.0 update coming for camon 11 devices ?? and the fonts too ??
                          :0x1f496::0x1f496::0x1f496::0x1f496::0x1f633::0x1f 637::0x1f637::0x1f637::0x1f637::0x1f637::0x1f637:: 0x1f637::0x1f637::0x1f637::0x1f632::0x1f627::0x1f6 27::0x1f627::0x1f625::0x1f625:
                          Enjoy immersive viewing pleasure on your Camon 11 and 11 Pro by switching to Android 9 Pie Gesture navigation that has beenxdffggg made available on the Camon 11 and Pro it allows you to operate your device fluidly and intuitively through the interface compared to On screen navigation button we have been used to.<br />
                              Nice one op.
