  • My tecno c11 pro battery drains down Nigeria
    I recently bought the tecno c11 pro, not up to a month but I've noticed that each time I charge my phone and go to be by morning the battery will drop from 99%-94+% every time
    I'm sure you are using your device...
      you're not alone.. My Camon X does same... 100- 98%(Often) 99-96%( This Morning)
        Camon x, 11, pro, x pro are all the same
          my battery drops... maximum 1%...from 100% to 99%
            And data off tho
