  • Tecno CM Battery Drains -Solution Nigeria
    Hi all and Good day. Please my Tecno CM battery drains so faster than when first new. What do I do? thanks
    Try to run maintenance check on ur phone then reboot the phone after the maintenance check.
      nice sharing amazing one keep sharing thanks for all
      http://www.mobile-phone.pk/upcoming-mobiles/
      http://www.gari.pk/used-cars/
        Make sure no app is using notification access and your battery will be fine
          Check the apps you run on your phone and the background apps, your screen brightness and some other stuff
