  • battery fix Kenya
    can camon 11 battery be replaced???mine doesn't stay on so long with charge...i need a new battery
    is the phone hot
      mine doesnt last at all
        Originally posted by 8036656240
        is the phone hot
        yeah..at the fingerprint area
        • 8036656240 commented
          back your data's and restore factory settings
          aftet dat it wil be ok
        mine to..can the battery be replaced
          I think you guys should find any Carlcare around you and go there.
