  • Android Pie Custom rom for Tecnon Camon 11 CF7 All
    Descendant TwoDotTwo Android 9.0 Pie custom Rom for Tecno Camon 11 CF7 (KA7) running Android 8.1.0. Descendant TwoDotTwo is an AOSP base OS with a lot of performance and customzation options. So, if you're looking for Android Pie Custom ROM for Tecno Camon 11, try TwoDotTwo.
    How to install Descendant Custom ROM for Tecno Camon 11
    1. Download Tecno Camon 11 Android Pie custom rom and vendor mod.
    2. Copy the downloaded GSI file to the root of your SD, if the ROM is in zip or rar format, simply extract it to get the img file
    3. Extract the Vendor Mod to a folder (we’ll be using it at the end of the installation)
    4. Now boot your device into TWRP recovery
    5. In TWRP perform a factory reset, or siply use the advance option to wipe the cache and data partition.
    6. Then tap of the install button, select the install image button on the next screen
    7. Select the ROM img file and select the system partition in which you want to install the ROM on the next screen.
    8. The installation process will begin, so sit back while it installs.
    9. Once installation is complete, don’t reboot just yet
    10. Now go to TWRP restore option and restore the Modded Vendor you extracted earlier.
    11. Once this is complete, now reboot.
    What about camon 11 cf7k
      This is a Welcome development, special thanks to the developer.
        useless techno people pls kindly give urs updates man don tire wona massa re we just gox to buy new techno phones all the time to meet up with updates rubbish
          would it work on camon 11 pro ????
            Yea can it work with camon 11pro
              they said no.
                We camon 11 pro user need this toi
                  give us Android 9 update, not dis pls
                    I don't like custom rom, I only prefer updating from manufacturer
                      It's sad to know Tecno is promoting custom rom ( which comes with one or two issues). Infinix made android pie 9 update available for its users. Tecno can't do same yet, they see infinix as competitors. You loss already!
                        هلا
                          l love TECNO. for everything
                            Please am trying to download the custom rom of android pie for camon 11 but did not succeed it taking me to and ad page named adfly
                              If it's not from the manufacturer am not updating before your phone will crash now
