  • compliant on an issue Nigeria
    my camon 11 battery don't last
    You bought yours when?
      February 18th,2019
        Please check your power settings, disable background apps. How long does it last?
          how can i do that
            Hello<br />
            Is your device up to date?
              Check your power settings and your background apps
                how can i check it
                  Originally posted by Ennyholar
                  Hello<br /><br />
                  yes
                    try using your power management app to optimize battery usage
