  • SD card doesn't show Nigeria
    After last update for CA7 SD card disappears from my phone and I have to reboot it before it shows. Anyone else experiencing this?
    check your storage settings
      After checking your settings you should restart the phone or restore factory settings
        I restart the phone anytime the SD card "disappears". It comes up for a few hours then disappears again.
