  • how to save battery Nigeria
    please, how do you care for camon 11 battery, to last longer
    stop using the phone
      You can try the following<br />
      1, use data when you actually need it<br />
      2, disable background app data usage and app activities<br />
      3, use automatic/adaptive dispaly<br />
      4, set back light to go off sooner.<br />
      5, use the battery saver option
        Try the above and give feedback
            To save the batter we can choose the guidance of some experts in the field of technical support. The experts are trained to handle all the difficult situation cheap real diamond rings online of the clients. By avoiding the overcharging and speed charging options the battery stays safe.
