  • Android 9 Pie on Camping X Pro CA8 Nigeria
    when are we going to receive the update to Android 9 Pie on the camon X / Xpro CA8? Best regards.
    Please where did you get the information that Camon X/X pro will receive Android 9 update?
      smiles<br />
        What about camon 11? Don't we deserve new android version... We should settle for 8.0 for life
          Tecno lacks the capacity to update old phones to new Os version... Simple...
            @Anaisor Kindly note that getting OS upgrade requires adequate test. Please be patient about it, Tecno will keep rolling out security updates and necessary bug fixes ASAP.
