  • Camon 11 pro's All
    Camon 11 pro's caméra is just good under sun light it can't zoom at close range (can't scan a letter using Camon 11 pro's everything is blurred) inside the house it produces poor quality colour in a nut shell I regret spending my money this piece Can't change font type. the notification light has got a unique colour chose what ever u which on an app but you still get white blink, this is just very poor. I bought this piece out of curiosity and am very disappointed. just my observations!
    Update your device<br />
    settings>>system>>System Update>>online update<br />
    update to the latest security patch level<br />
    go to play store search for HiOS launcher and check if its latest version<br />
    go to hi theme>>Discovery>>font>>download any font>>Apply
      after updating HiOS launcher go to apps search of it and clear all its data then run it afresh (apply the fonts)
        some people can complain.....<br />
        is it not d fone that I have been using for 9 months now.....<br />
        Oga u for buy Nokia 3310 na
