  • Swapping of phone All
    I want to swap my camon 11 to camon 12 .Please how do I go about it
    Check ur Carl care app for more details or search the t-spot
      Presently the swap plan is only available to carlcare service center in Lagos. When you submit your phone at the carlcare service center,you will be told how much your phone is worth and how much you need to add to get the phone of your choice.
        Take your device to Carlcare.
