  • Camon x keeps freezing Nigeria
    My camon x keeps freezing and it's becoming so annoying for me.. Please can anything be done?
    Kindly do the following:
    1. Free up internal storage,leave atleast 2gb free space.
    2, Clear cache using phone master.
    3. Update all your apps
    4. Close apps that you are not using,in order to free up ram memory.
      (a). Try and update the apps that freeze. <br />
      (b). From settings, open apps.<br />
      (c). Tap on the storage of the individual apps and clear their cached data. This will help.
        if all of the above fail... back up your files then perform a factory reset
          or rather if you are tired you can just switch the phone online with Carlcare
            If you guys can only see how beautiful it is when we all work together...
              You're right. It's more respectful and more friendly too. We must also consider the fact that no one has the monopoly of knowledge nor mistakes.
                free up some space on your device, lack of space usually causes lagging, your can also use your phone master app to clear cache and junk files.
