  • Camon 12 Charges slow Nigeria
    Hello. My new camon 12 Charges extremely slow. please what's the solution?
    Are you using the device while charging?
      Allow it charge, it won't discharge as fast
        I tot camon 12 comes with 2amp charger that gives 10watts basic speed
          Using your device while charging it does not actually prevent or slow down it charging. The device could be faulty or possibly the charger or cord
            I disagree with this, you cannot be using the device and expect it to charge as it should be. <br />
            Why do devices charge faster when switched off? <br />
            • tobentopaulo commented
              I refuse to concur with your submission. It's what I do on daily basis. I use my device while charging and it does not affect the charging rate. Even my sister's Infinix is used while on charge and it does not slow down the. charging process.
            • tolugaruba commented
              I give up...
            I agree with you! once your phone starts heating up, the charging speed will slowdown to reduce the heat.
            Originally posted by tolugaruba
            I disagree with this, you cannot be using the device and expect it to charge as it should be. <br /><br />
            Why do devices charge faster when switched off? <br /><br />
            creamtech.com.ng
            IG/TW @dc8official
              bro! it will be nice if you could tell of the estimated charging time. it might not actually be slow
              creamtech.com.ng
              IG/TW @dc8official
                it's d pro tat has 2amp<br />
                while d 12 has 1.2amp<br />
                so dere's different
                  Oh My!! I won't dare use my device while charging ever again.
                    Oh so u been dey do am b4, better ready to buy battery soon if u no stop.
                      camon 12 charger is fucking bad, i just need to get a new charger.
                        just loving the 10gig simo free data on camon 12
