  • camon 12 lock screen wahala Nigeria
    I duno if its a problem or its how d phone is. I'm using face id to unlock my phone. if d phone is locked, weneva I'm holding it. d screen will keep turning off and on all d time. I dunno y. is it OK like DAT for d fone to b in auto screen on and off mode? pls help me out here.
    It's like that, it's trying to read your face, and the raise to on is also active
      Give more details
        wat do u mean by 'raise to on'?
          There is an option in motion intelligence raise to wake, disable it.. Then you will okay
            bro.. tnx a lot. I've seen it.
