  • CAMON 12 SMS Nigeria
    PLS HOW DO I SEND TEXT MESSAGES TO MULTIPLE PHONE CONTACT AT THE SAME TIME ON CAMON 12. THANKS.
    go to Ur Message app select the contacts you wish to send the Message it will give u an option to create a name for the selected contact group but you can skip the naming and go to next then type ur message to the selected contact and send <br />
    hope this helps
      Works this way on camon 11, don't knkw of camon 12 though but give a try and lets see.
      Launch the sms app, type in your messages and when you are done, click on the circled pathway in the pic below. It will take you to your contact where you can select recipients as much as you want.
      Or you can just type in their names on the place where it says "type name or number" as you do, it will give you list of names close to what you've typed from your contact list, select the one you want and repeat the process again to add more names.
