  • Failure to receive some messages at times on Techno C8 All
    My Techno C8 doesn't receive some texts at times. I updated the phone to Android 6.0 with HiOs but the problem still persist all the way from my previous version of android 5.1. Is there anyone else who has experienced such a problem here? I have tried to factory reset the phone for several times but the problem still persist. I have even replaced the sim cards but all in vain. Since the phone is dual sim,even after calling both service providers,they are insisting that the problem isn't on the sim cards. Kindly, can someone assist me. Thanks and blessings
    Wilson Waigwa
    maybe its a problem with your particular device
    • Wilson Waigwa commented
      I have noted the same complain from another person too
    Hey,downgrade it back to android 5.0.1 and give me feedback!
      Thanks. Although the same problem still existed even in android 5.1.
    i had the same problem too while using lollipop so i thought after marshmalliw update the problem would go away but its just the same thing.....so Tecno should do something about it
      It's terrifying, it doesn't receive text messages at times. You have to send it to me like 3 or 4 times before it will show, at times it might take a longer period to show. Please how can I fix this?
        Am experiencing the same problem
          Same here
            I wish I could help. Perhaps factory settings or flashing might help. Alternatively install hangout, it works too
              Can someone really help?
                How to downgrade adroid 6 to 5.0.1 lollpop for tecno c8
                  Same problem here...so annoying...any solutions?
                    I have the same problem, and i suspect i have missed important messages. anyone who got a solution...
