  • WHAT YOU SHOLD KNOW CAMON C8 RUNNING 6.0 All
    If you just buy tecno camon c8 after successful upgrade to 6.0 i emplore you to do a factory reset its the best thing i will tell you to do because of some bugs
    Why?
    • Charlae4ive commented
      because it will help free from bugs
    yes thats true because the first time i upgraded to 6.0 without factory reset i encounted allot of annoying things so i downgraded to 5.0 then upgraded+factory reset and everything is cool now
    • jostop2050 commented
      How did you downgrade it to lollipop 5? Direct me please!
    • BenKafor commented
      Ha
    • Brightmore commented
      Please how can I downgrade to 5.0?
    But why???
      This OP is funny oo. Your post is not a complete one, You should give reason why you want us to factory reset it and have you done so with your own
        Nice info
        Good one
          Exactly and that's one very important point most of skips ....!
          +255744123365
            Lol nawa
              So stability is gained by flashing followed by a factory reset? That has been noted
                Which mode of flashing?
                not flashing but factory reset
              Noted
                true, factory reset imm after you upgrade.
                  Plus camera quality? Lol
                    my only issue now is the way apps close themselves while using them....most especially bbm.... it's really annoying...
                      how do I downgrade? Pls put me tru
                      • ugosteve commented
                        Kay please help me, what do I do and how do I go about it, should restore factory settings before I upgrade to 6.0 ?
                      • Kaykerry commented
                        yes
