  • 2 Tap wake up/sleep , doesn't work with the cover... ??!! All
    Does anyone face this problem....!!!
    Do you mean the tap to wake features doesn't work...
    When your device is cover with the cover case....
    • fadyfayz commented
      Yes
    • Ennyholar commented
      Bro the feature won't work when your phone is covered.
    2 tap wake DOESN'T work when you have the top flip of the cover on your screen.
    The cover changes your phone into something different, and, after all, the screen is hidden and only a small part is left out. How do you tap the screen with the case on?
      I'm confused
        I guess he is talking about c9<br />
        he means the when he tap twice on the circle which shows the clock the phone doesn't light up<br />
        am i right?? <br />
        if so it's normal the screen doesn't work when it's covered.. the only way to make it work is to press the power button..
          same guy more complains.. Wea did u get the phone from?
          • Frozercold commented
            i think you should locate a carlcare center closest to you there n lay ur complains
