  • How could Edit tool bar Functions doesn't Exit ...!!!!! All
    How could Edit tool bar Functions doesn't Exit ...!!!!! (how to edit the shortcuts displayed the the notification bar)
    i don't understand
    • fadyfayz commented
      I want to management functions or edit from tool par
      That's not available ....!!!
    Please explain yourself
    +255744123365
      That's not available ....!!!!
    I do not understand
      I want to management functions or edit from tool bar
    It doesn't exist because all the shortcuts are visible. You will only need edit button when the shortcuts are more than the space provided and therefore the need to manage them.
      You means edit functions doesn't exist ..!!!
    • Micahyaw commented
      Sorry but you can't edit the notification shortcuts
    elaborate pls
    • Frozercold commented
      if its the status toolbar aka notification bar, you cant edit it.you only turn it on or off. you can only manage apps on ur home screen.
