  • having problem All
    my Tecno w3 anytime someone calls always busy signal. what is the problem and the solution.
    Looks like you have your do not disturb settings active, disable it to allow calls come in
      I have disabled it but no change
      • tolugaruba commented
        Call your network provider to check if the issue is from them
