  • hanging phone All
    Good evening all,please I have a techno canon x that is hanging,not until I power off and on again it will still be hanging. what can I do and how do I go about it. thanks. Bolaji Lagos.
    Has your device its latest update?. If it has, you may need to do factory reset to enable the system function properly. Don't forget to backup your personal files and data before resetting the device. If the problem persists after reset, visit the Carlcare center nearest to you for professional solution.<br />
    Good luck.
      Originally posted by ezeukwuezeleke
      Has your device its latest update?. If it has, you may need to do factory reset to enable the system function properly. Don't forget to backup your personal files and data before resetting the device. If the problem persists after reset, visit the Carlcare center nearest to you for professional solution.<br /><br />
      Good luck.
      Best solution ☝️
        lack of storage can cause lagging, try freeing up some space and use your phone master app to clear cache and junk files
